Activity Forums DVD Authoring high frame rate = lost of synchro
  • high frame rate = lost of synchro
    Posted by Macmauro on April 9, 2006 at 9:06 pm
    hi; i edited a video where images are very fast – still images that sometimes appears at speedness of 1 every 2 frames-
    i compressed the video with Compressor; trying different compression and variable bit rates;
    the result is that suddenly the synchro between audio and video is lost
    the music is faster than; also if at the end of the video every thing return fine.
    what could i do to avoid this?
    thanks
    M.
    Macmauro replied 20 years, 5 months ago 2 Members · 2 Replies
  • Daniel_l
    April 11, 2006 at 11:17 am
    What are your compression settings?
    Video AllSorts
  • Macmauro
    April 12, 2006 at 7:13 pm
    hi
    i used all the kind of standard compression available in compressor
    all pal anyway
    but the problem was always there
    60 minutes HQ, 90 min 120 min and so on…
    i tried to made a dvd of the same video using a dvd recorder (yamaha drx1)
    at high quality too and the result was very fine
    but in this case i can’t insert a menu as i do using dvd studio pro
    any suggestion?
    thanks
    M.
