Activity Forums VEGAS Pro High Dynamic Range
  • High Dynamic Range
    Posted by Stewart Newell on October 9, 2018 at 3:59 pm
    Has anyone successfully produced an HDR video using Vegas 16 PRO ?. I have tried using Sony Slog3 footage with ACES colour settings, Slog3 transforms and Rec2020/HEVC rendering. When transferred to a memory stick and played on my Samsung HDR TV the result is less than spectacular and not as good as a standard Rec 709 picture. The TV quite happily displays HDR downloads from Youtube.
    Mark Thompson replied 7 years, 11 months ago 3 Members · 3 Replies
  • Aaron Star
    October 14, 2018 at 5:59 pm
    Can you post media info on your camera original footage? A long with details on the project settings in vegas and render output?
  • Stewart Newell
    October 15, 2018 at 9:25 am
    The footage was shot on Sony FS5, picture profile 8 Slog3.SGamut3.cine
    In Pro16 I used the following project settings:
    Custom 1920×1080 25fps.
    Pixel Format 32bit floating point(full range)
    Aces version 1.0
    Aces Colour ACEScc
    View Transform Rec2020 ST2024 1000nits(ACES)
    Clip properties
    Sony Slog3.SGamut3.cine
    Render settings Video HDR10HD
    encode mode Mainconcept HEVC
    project tab colour space REC2020 ST2024(1000nits)
    This renders successfully and it transfers ok to a memory stick…it just won’t play correctly on the TV.
    Since posting my original message I have received the following advice from Magix support:
    Unfortunately the features you are looking to do are not yet available yet in VP16 for these specific settings, however, the features needed are scheduled for our next update of Vegas
  • Mark Thompson
    October 15, 2018 at 4:16 pm
    I’m mainly on Premiere Pro these days and have had a little luck with that.
    I would suggest loading up to YouTube and then display on your TV.
    When you upload YouTube will tell you whether it has recognized it as HDR. But be patient it uploads the lower resolutions first and it might take 30 minutes before you can see it.
    Upload in H.264. Yes it should be H.265 and it may well be soon but YouTube seems to like H.264 for now.
    The challenge is to get the right Metadata with it. PPro seems to do that at the moment (the 2018 release).
    If that fails YouTube publish some instructions.
    Start here: https://support.google.com/youtube/answer/7126552?hl=en
    There is a better note that tells you how to add the correct metadata (MaxFALL, MaxCLL, or Master Display metadata)
    If that fails I’m afraid it is FFMPEG
