Activity Forums Adobe Premiere Pro High CPU Utilization when clicking on Timeline
  • High CPU Utilization when clicking on Timeline
    Posted by John Riker on December 3, 2013 at 5:37 pm
    I am using Premiere CC and have an hour twenty minute video loaded in. MP4 and not oversized. 4.8GB. Everytime I click on the timeline, my 12 core system jacks up to almost 80% utilization for about 2 minutes before showing the spot I clicked on the timeline which was about 30 seconds further on the timeline. Short of rendering for hours why is this happening? I haven’t had this problem with the other four videos I’ve worked with.
    NOTE: I did a basic render of the scene and didn’t do any good.
    Here are some stats on the video in question:
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1h 20mn
    Bit rate mode : Variable
    Bit rate : 8 024 Kbps
    Maximum bit rate : 24.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.129
    Stream size : 4.49 GiB (100%)
    Writing library : x264 core 120 r2120 0c7dab9
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=0 / keyint=20 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=29 / rc=2pass / mbtree=1 / bitrate=8024 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Thanks.
    JR
    Peter Garaway replied 12 years, 9 months ago 2 Members · 1 Reply
  • Peter Garaway
    December 4, 2013 at 4:19 am
    Are you on 10.9 Mavericks? I’ve heard a few cases of this happening, but I’ve never encountered the issue myself.
    Would be interested if you have a reproducible case.
    Peter Garaway
    Adobe
    Premiere Pro
