Activity › Forums › Adobe Premiere Pro › Hiding the Audio Channel Overlay in the Timeline
  • Hiding the Audio Channel Overlay in the Timeline
    Posted by Jason Guerra on June 13, 2014 at 7:14 pm
    Hey, this is one on those, hopefully, really simple easy things, that I am just overlooking. In the Timeline, on the audio tracks there is a little overlay with the audio channel. It appears on each track, after each cut. Is there a way to turn that off?
    Part of my problem in finding a way to turn them off, is I don’t actually know what they are called. Below is a screen shot.
    Andrew Kimery replied 12 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Andrew Kimery
    June 13, 2014 at 10:20 pm
    In the Timeline Display Settings (looks like a wrench in the upper left hand corner of the timeline, below the timecode display) you can uncheck “Show Audio Names”.
  • Jason Guerra
    June 13, 2014 at 10:49 pm
    Sadly, that is not it. I have the audio names turned off, and it still displays the channel overlay.
  • Andrew Kimery
    June 14, 2014 at 12:00 am
    bummer. Which version are you using?
  • Jason Guerra
    June 14, 2014 at 12:18 am
    7.2.2 (33)
  • Andrew Kimery
    June 14, 2014 at 8:41 pm
    That’s the same version I have but the Audio name toggle seems to work for me. When you toggle that setting on/off does anything change (like more info gets added when it’s ‘on’)?
  • Jason Guerra
    June 15, 2014 at 3:59 pm
    The “Show Audio Names” toggle works fine for me, and does exactly as the name implies. When it’s on, I see the file name in the timeline, when it’s off I don’t. It doesn’t affect anything else on my machine.
    So, the channel badge seems to be unrelated. The only thing I have found that turns off the channel badge is the hide the wave forms, but that’s completely counter productive for me. The reason I want to turn them off, is they are obscuring some fine details of the wave from.
  • Andrew Kimery
    June 15, 2014 at 7:21 pm
    I never noticed the channel badge staying the whole time but it seems that it does. Time for a feature request!
