Activity › Forums › Avid Media Composer › Hiding Hard Drive
Hiding Hard Drive
Posted by Michael Volkening on April 30, 2009 at 6:03 pmI recently added a non-Avid external hard drive to a system I work on regularly, for misc. file storage- audio files, graphic elements, text stuff, etc. Is there a way to hide this drive from the Avid so it does not appear in save to/render to options? I can see myself rendering to it by mistake.
Avid Express Mojo 5.5.3 Windows 2002
Mikey
Joe Womble replied 17 years, 4 months ago 5 Members · 8 Replies -
Joe Womble
April 30, 2009 at 7:06 pmMichael,
You can do this by going to Drive Filtering in the General Settings. It also exists on the Change Group window (on the target drive pulldown) in the Digitize Tool.
Set it at the beginning of your edit session and it should not change.
Regards,
Joe Womble
Michael Volkening
April 30, 2009 at 7:22 pmCool beans. Does that need to be done each session, or just once?
Joe Womble
April 30, 2009 at 7:53 pmShould hold. I’ve heard of others who have found this defaulting back to where it was previously set, but I haven’t had this problem. Try setting it the way you want, save all and then close out Avid. Restart and see if it holds.
Regards,
Joe Womble
Kris Anderson
April 30, 2009 at 10:35 pmI use the filtering options and for some reason it always resets on a new project. Drives me nuts! Hope it works for you.
James Beattie
May 1, 2009 at 1:11 amYou can make the setting permanent for each project you create. Click on the settings Tab in the project window, and modify your Media Creation settings. Then in the upper left monitor choose Special->Site settings. This opens a floating window. Drag the Media Creation line to the Site settings window, and you will see it populate. Now, you have created a Site setting that will be observed whenever you create a new project. Old projects still need to be manipulated.
–James
Terence Curren
May 1, 2009 at 5:27 amYou can also “lock” a drive temporarily so that Avid can’t write to it by locking the Avid Media Files and OMFI folders on that drive.
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca -
Joe Womble
May 1, 2009 at 11:43 amJames Beattie has built several systems for me over the years…they have always run flawlessly. James is a great source of information and hip to all things Avid.
Thanks, James!
Regards,
Joe Womble
