Activity › Forums › Audio › Hiding extra wireless bodypack mic cable
  • Hiding extra wireless bodypack mic cable
    Posted by Chris Walton on April 16, 2013 at 7:17 pm
    I am hoping someone out there might have a slick trick they can pass along.
    I am doing a lot of standup, walk-and-talk interviews using a wireless mic system. I know I shouldn’t wrap the excess mic cable around the interviewee’s body back before placing it in a pocket, nor should I wad it up in the same pocket or allow it to accidentally come in contact with the antenna.
    Any tips as to what can be done to hide the cable, keeping it from causing audio issues in a way that allows me to mic the subject quickly? I should mention that I have no control over wardrobe other than requesting interviewees have pockets or a belt. Clips, tape….?
    Chris
    Chris Walton replied 13 years, 5 months ago 3 Members · 5 Replies
  • Eric Toline
    April 16, 2013 at 7:35 pm
    I’ve done all the things you say you shouldn’t do and can’t recall any problems. Have you had any problems?
    Eric
    “I push the RECORD button and hope for the best”
  • Chris Walton
    April 16, 2013 at 7:42 pm
    I have had problems but of course who is to say the problems were unquestionably caused by the mic wire. From what I have read it seems to be a pretty common recommendation.
  • Eric Toline
    April 16, 2013 at 9:28 pm
    Not saying you’re wrong but FWIW, Read my signature line.
    Eric
  • Joel Servetz
    April 17, 2013 at 12:31 pm
    Chris, while technically what you’re saying seems like it should make sense, as Eric said I’ve also done all of the above and never encountered any problems. I’ve been on literally hundreds and hundreds of interview shoots in offices, homes, operating rooms, Central American rainforests, construction sites, skyscraper rooftops, etc., etc., and never a problem with where or how I stowed the extra mic. cable. If someone has suggested otherwise I would be suspicious of their particular piece of equipment, perhaps a broken shield or some other cable malfunction.
    Joel Servetz
    RGB Media Services, LLC
    Sarasota, Fl
    videobyjoel@aol.com
    http://www.rgbmediaservices.com
  • Chris Walton
    April 30, 2013 at 1:59 am
    Hey Guys,
    Thanks very much for your feedback. I’ll just keep winding as I have always done.
    C
