Activity Forums Adobe After Effects Hiding a dead pixel (with AE)?
  • Hiding a dead pixel (with AE)?
    Posted by Janne Laiho on August 18, 2015 at 10:29 am
    Hello,
    a film I’m color grading has footage where the camera had a dead pixel. The pixel shows as pure white. The editor has moved clips vertically, so that the dead pixel is seldom in the same place.
    I tried overlaying a 50% gray pixel on top of the dead one to make it less appartent. Works somewhat, however I’m wondering whether I should use a track matte of some sort (or something else) in AE to try and get rid of the dead pixel altogether.
    How would you use AE (or some other tool) to hide a dead pixel from footage? Thanks.
    cheers
    Janne
    Janne Laiho replied 11 years, 1 month ago 5 Members · 5 Replies
  • Jürgen Hackl
    August 18, 2015 at 11:11 am
    I’d duplicate the layer, shift it by one pixel in any direction and draw a mask over the dead pixel.
  • Jim Arco
    August 18, 2015 at 12:21 pm
    I usually put a copy of the footage underneath the original and offset it by several pixels, then blur it slightly. It is relatively easy to ‘cut a hole’ in the original at the location of the dead pixel because it is pure white.
    Since the original moves around, you’ll need to somehow track the offending pixel.
    Jim
    ColorBurst Video
  • Chris Wright
    August 18, 2015 at 4:44 pm
    dead pixel 6 will remove up to 3 specks with thickness, remove speck and visible boundry box.
    Ae6
    https://f1.creativecow.net/6195/dead-pixel-6
  • Daniel Waldron
    August 19, 2015 at 2:45 pm
    You can also use CC Simple Wire Removal. Just put the two wire points really close together over your pixel.
  • Janne Laiho
    August 19, 2015 at 3:10 pm
    Thanks all! The CC Simple Wire Removal did the job.
