Activity Forums Adobe After Effects Hide/Reveal Text
  • Hide/Reveal Text
    Posted by Ricky Peddicord on March 8, 2015 at 4:37 am
    Basically, I’m doing a frame-by-frame revealing of text. I want the text to start out completely hidden and then slowly reveal itself. The only way I’ve currently thought of doing it is with black squares moving further away from the text, but I can’t seem to get the black square to 100% match the black color used in the background, so I’m wondering if there is any alternatives to doing this.
    John Cuevas replied 11 years, 6 months ago 2 Members · 1 Reply
  • John Cuevas
    March 8, 2015 at 6:49 pm
    Place a mask around the text layer, keyframe the mask. Or just use the black solid above the text layer you already created as a track matte. Select the text layer, press f4 to reveal track mattes, place the text directly below the black layer in the layer stack and change the track matte to “alpha matte”.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
