Activity Forums Adobe Premiere Pro hidef slideshow question
  • hidef slideshow question
    Posted by Carl Endres on March 19, 2008 at 10:14 pm
    I am putting together a slideshow using Premiere pro made up of only still images. The stills were shot at 3702×2304. I am trying to get the best possible picture quality when viewed on a 1080p hidef TV. Unfortunately it will be played on a standard DVD player not Blu Ray. My questions are
    1) could I use the hdv1080p(1440×1080)preset to create and author the project. And would this give me the best overall quality.
    2) What problems if any should I expect if this project is viewed on a standard def TV through a Standard DVD player.
    Thanks for any help you can offer- Carl
    Carl Endres replied 18 years, 6 months ago 2 Members · 2 Replies
  • David Dobson
    March 20, 2008 at 1:28 am
    HDV will work fine. When you export for DVD from the HDV Project, you should chose a widscreen (16:9) setting. On a standard def DVD player on a Standard def TV you will get a letter box version. With a standard def DVD player on a widescreen TV it should play wide screen.
  • Carl Endres
    March 20, 2008 at 1:53 pm
    Thanks for the reply David. I’ll give it a try this weekend.
