Activity Forums Maxon Cinema 4D Hide original object when Symmetry is used
  • Hide original object when Symmetry is used
    Posted by Jeremy Paul on August 9, 2017 at 3:11 pm
    I’ve got an object with a bunch of keyframes set on it. I would like to create exact symmetry of that object, but hide the original copy.
    I used Symmetry from the Modeling tab, which handles the symmetry problem. Now I just need to hide the original. How can I do that?
    Steve Bentley replied 9 years, 1 month ago 2 Members · 3 Replies
  • Steve Bentley
    August 9, 2017 at 4:39 pm
    You can collapse the symetry to polygons the same way you would for a primitve and then delete the original object. Depending on the object type you may have select it’s points and delete those. The two objects will be joined into one so just select the points of the first one and hit delete. The animation track will remain.
  • Jeremy Paul
    August 9, 2017 at 5:26 pm
    Thanks! This is a great way to do it.
  • Steve Bentley
    August 10, 2017 at 4:05 pm
    But this is a destructive method and you can’t go back to adjust., So I usually make a copy of the symetry set up before I collapse it and then hide that for editing down the road.
