Activity Forums Apple Final Cut Pro Hide (or toggle off) the Active Clip Frame?
  • Hide (or toggle off) the Active Clip Frame?
    Posted by Ernie Munick on March 30, 2017 at 4:50 pm
    Is there a way to hide or toggle off the frame around the active clip in the viewer, so I’m just seeing the clip and can move the clip around, without seeing the frame (wrong word, I think) around it?
    Bret Williams replied 9 years, 5 months ago 3 Members · 3 Replies
  • Jeff Kirkland
    March 30, 2017 at 9:15 pm
    Not if you are manipulating it directly with th\e mouse but you can move it by scrubbing the coordinates in the info panel without activating the frame. That’s how I move things 90% of the time.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Ernie Munick
    March 30, 2017 at 10:29 pm
    Yeah, but that frame covers a bit of the edge, which is why I’d rather make the frame disappear. And then, as you said, use the parameters instead of the mouse.
    Thank you!
  • Bret Williams
    April 1, 2017 at 12:05 am
    There won’t be a frame if you use the inspector while in regular arrow (A)mode.
    _______________________________________________________________________
    https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
