Activity › Forums › Apple Final Cut Pro › Hide all Used clips in all Projects
  • Hide all Used clips in all Projects
    Posted by Xavier Paredes on August 2, 2018 at 7:12 pm
    My workflow often requires me to work with several projects in the same Event. Because sometimes I have a lot of source clips, I would like to know if there’s a way to hide all clips that have been used in ANY of my projects within that Event. Possible?
    I know it’s possible to use Keywords to filter the browser results but I wonder if there’s a better way that doesn’t require me having to remember to assign the keyword every time I use a clip.
    For example, if I click on the Event and then choose “Unused” from the browser drop down menu, it seems it only hides the clip(s) that are not being used in the currently open project.
    Xavier
    Scott Witthaus replied 8 years, 1 month ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 2, 2018 at 7:45 pm
    I don’t know of a way to do this across multiple Projects without some sort of work around with compound clips, or copying/pasting all projects in to a master Project.
    Also, take a look at the Producer’s Best Friend app from Intelligent Assitance to generate a report for you if that helps.
  • Scott Witthaus
    August 3, 2018 at 1:11 pm
    Certainly interesting and worth putting in the “suggestion box”.
    Scott Witthaus
    Visual Storyteller – FCPX, Premiere
    https://vimeo.com/channels/1322525
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
