Activity › Forums › Blackmagic Design › Hi8 into FCP via Blackmagic Extreme HD 3D Card
  • Hi8 into FCP via Blackmagic Extreme HD 3D Card
    Posted by Peter Kaminski on August 23, 2010 at 2:17 am
    Hi guys,
    I’ve just set up a FCP system on an 8-core Mac Pro.
    I added the Blackmagic Decklink HD 3D card today. It has the breakout cable that comes as standard, the studio breakout cable.
    I have old footage in a Hi-8 camera that I’m looking to get into FCP.
    First, the connections. My outs on the camera are two rca’s a yellow and black, picture and sound. This is a dumb question but what’s the BEST way to connect these two RCA’s to the decklink card so that I can import.
    Second, my system profiler doesn’t see the Decklink card, and I’ve installed the driver. Any ideas there?
    Thanks a lot for any help!
    Peter Kaminski replied 16 years, 1 month ago 2 Members · 2 Replies
  • Larry Brewer
    August 24, 2010 at 7:42 pm
    Peter
    The best way to import Hi8 footage into your PC is with a firewire. Obtain a Sony Digital 8 camcorder, a camcorder that used 8mm video cassettes but records in a digital fashion very similar to DV cassettes.
    Most of these camcorders were backward compatible with standard 8mm video and Hi8 video cassettes. This gives you a playback and a conversion to firewire in one step, and control of the camcorder via the firewire cable.
    I assume your PC already has a firewire or IEEE 1394 jack. If not, the card is about $20 and Ulead software comes with most of the cards. Windows also has a capture utility for the firewire port.
    Just finished uploading 45, Hi8 cassettes to a 1 TB hard drive using a Digital 8 camcorder I bought on eBay for $85. Well worth it.
    Captured video used about 13 GBs per hour.
  • Peter Kaminski
    August 25, 2010 at 10:46 am
    I’m getting some BNC to RCA adapters to get the media in. And the card started showing up after a restart.
