Activity › Forums › Apple Final Cut Pro › Hi there!
Hi there!
Posted by Severus Smith on December 1, 2023 at 3:17 pmCan someone here help me with finding few totally free plugins? I badly need tracking plugins, thanks .
Mads Nybo jørgensen replied 2 years, 9 months ago 4 Members · 3 Replies -
Jeremy Garchow
December 1, 2023 at 8:04 pmI think you will have a difficult time finding a free tracking plugin. FCPX has tracking in it, though, so what kind of tracking do you need to do?
Brian Thomas
December 3, 2023 at 9:36 amI’ve used the relatively new built-in tracking feature and it’s so easy to use. It works really well too.
Mads Nybo jørgensen
December 5, 2023 at 7:22 pmHey Severus,
If you don’t already have it, there is adobe After Effects that you can download on a free trial.
It has a lighter version of Mocha included as standard.Adding that BoriFX will also allow you to use Mocha Pro for two weeks:
https://borisfx.com/products/mocha-pro/Coremelt, which is very much a FCPX plugin (with some of the packages using Mocha) also has a free trial:
https://coremelt.com/Just keep in mind, that you get what you pay for – as unhelpful that is, it may be a better longterm solution for you to follow the advice above and go with the internal tracker ion FCPX.
Madsborisfx.com
Mocha Pro is an award-winning planar tracking tool for motion tracking, rotoscoping, object removal, camera stabilization and general visual effects.
