Activity › Forums › VEGAS Pro › Hi-Resolution problem
  • Hi-Resolution problem
    Posted by John Perez on May 3, 2018 at 2:34 am
    I’ve shot “HD 21:9 Cinema” on my cell phone. The frame size is 2560 X 1080, but the image is pixillated when it should be razor-sharp, right? Below is a link to the shot. Please help….
    https://www.youtube.com/watch?v=Cb43kpRdQkU
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    Francois Pénzes replied 8 years, 5 months ago 2 Members · 4 Replies
  • Francois Pénzes
    May 4, 2018 at 10:03 am
    Hi John
    Frame size is only one thing. Is that end result from the original file on your phone or is this from after it was dropped in Vegas ?
    MediaInfo on the original file would help.
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14
    \’\’When the cutting stops, the editing begins…\’\’
  • John Perez
    May 4, 2018 at 11:31 am
    Clip info: 2560 X 1080,
    :38 secs duration,
    24 fps
    17,139 kbps
    19,460 Total bitrate
    Is this the file info you requested?
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
  • John Perez
    May 4, 2018 at 11:42 am
    Yes, that’s it! The original clip plays fine in the Windows movie viewer , but get pixillated in Vegas and the exported file.
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
  • Francois Pénzes
    May 4, 2018 at 6:57 pm
    Hi John
    Is the original clip 24 fps exactly ? or is it something like 23.(decimals) ?
    That is why MediaInfo is useful, it tells you exactly what the frame rate is and a whole lot more.
    Vegas doesn’t like files that have a variable or weird frame rate. Try converting your file to a constant frame rate with software like Handbrake.
    Cheers !
    Vegas Pro 14
