Activity Forums Apple Final Cut Pro Legacy Hi Quality youtube files
  • Hi Quality youtube files
    Posted by Jennifer West on May 7, 2009 at 11:55 pm
    Hello
    I havent been able to get a good quality picture on youtube on a short video yet and have been trying different methods.
    Both videos are short, 1 is 39 seconds with no sound and the other is 2 and 1/2 min. They have no sound – and are NTSC standard DV clips. Youtube recompresses them and they look awful.
    These are the 3 methods I have used.
    1) MPEG4 (using H.264 720 x 480 30progressive deinterlaced) exported from Final Cut Pro 6 using Compressor. these files are perfect when I have uploaded to a private web with no compression but looked horrible on youtube
    2) Read on blogs to try this: FCP out with Compressor – same settings as above except using 640 x 480 H.264 as a .MOV file. Looked ok for first 10 seconds, then heavy pixellation
    3) Standard QT out of FCP – obvioulsy did not work
    I’ve been scouring the web and reading blogs and need to try to get to look just “okay” – not its looks horrible
    I also have flash – should I important a QT movie into Flash and export that way?
    How about this Compressor plugin that you can download – HQ Youtube setting?
    thanks, Jennifer West
    Chris Borjis replied 17 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    May 8, 2009 at 12:09 am
    I’ve made a lot of beautiful videos up on you tube.
    your really close. 4:3 is 640×480 (widescreen should be 864×480)
    set the h.264 video bitrate for 2,000 kbps for video.
    set the Mpeg-4 AAC audio bitrate for 160kps.
    I use mpeg stream clip to do this. perfect results every time!
  • Jennifer West
    May 8, 2009 at 12:15 am
    Hi
    Thanks for the tip.
    Is the MPEG stream clip in Compressor as an option?
    Thanks, Jwest
  • Chris Borjis
    May 8, 2009 at 12:20 am
    mpeg stream clip is a free application.
    I don’t know how anyone could survive without!
    https://www.squared5.com/svideo/mpeg-streamclip-mac.html
  • Jennifer West
    May 8, 2009 at 12:49 am
    Thanks, do you deinterlace?
  • Jennifer West
    May 8, 2009 at 3:27 am
    I tried the MPEG program you sent the link for – and it looked better – should I be exporting a standard QT out of Final Cut to use – or an uncompressed QT?
  • Maurik De ridder
    May 8, 2009 at 7:40 am
    You could also try exporting from FCP as Photo JPEG (75% or 90%)
    And upload that to youtube (max 1GB)
    greetings Maurik de Ridder
    Freelance Editor
    PowerMac G5 Quad 2.5GHz, 6.5 GB RAM, Multibridge Pro,
    ATI Radeon X1900GT
    QT 7.5.0 FCP 6.0.4 Color 1.0.2 Compressor 3.0.3 Episode 5.0.1
  • Chris Borjis
    May 8, 2009 at 4:05 pm
    [Jennifer West] “Thanks, do you deinterlace?”
    only if the video is interlaced.
  • Chris Borjis
    just export a quicktime as is.
    that usually works since it ends up being a much smaller rez on you tube.
