Activity Forums Compression Techniques Hi quality youtube files
  • Hi quality youtube files
    Posted by Jennifer West on May 8, 2009 at 12:00 am
    Hello
    I havent been able to get a good quality picture on youtube on a short video yet and have been trying different methods.
    Both videos are short, 1 is 39 seconds with no sound and the other is 2 and 1/2 min. They have no sound – and are NTSC standard DV clips. Youtube recompresses them and they look awful.
    These are the 3 methods I have used.
    1) MPEG4 (using H.264 720 x 480 30progressive deinterlaced) exported from Final Cut Pro 6 using Compressor. these files are perfect when I have uploaded to a private web with no compression but looked horrible on youtube
    2) Read on blogs to try this: FCP out with Compressor – same settings as above except using 640 x 480 H.264 as a .MOV file. Looked ok for first 10 seconds, then heavy pixellation
    3) Standard QT out of FCP – obvioulsy did not work
    I’ve been scouring the web and reading blogs and need to try to get to look just “okay” – not its looks horrible
    I also have flash – should I important a QT movie into Flash and export that way?
    How about this Compressor plugin that you can download – HQ Youtube setting?
    thanks, Jennifer West
    Barthelemy Glumineau replied 17 years, 4 months ago 3 Members · 2 Replies
