Activity Forums Apple Final Cut Pro Legacy Hi… Just a compression Length question
  • Hi… Just a compression Length question
    Posted by Conan Stott on July 27, 2008 at 9:24 am
    Hi there.
    I have a 2008 mac pro, 8 core, 6 gig ram.. and I am compressing a 22.5 minute HDV Apple Pro Res HQ project to DVD Best Settings…. the time it take is usually between 3 – 4 hours… is this normal or could I have a setting wrong somewhere? I export directly to compressor from FCP.
    Thank you
    Conan
    Michael Sacci replied 18 years, 1 month ago 2 Members · 1 Reply
  • Michael Sacci
    July 27, 2008 at 6:31 pm
    It always takes longer to encode when exporting from the sequence to Compressor (But I think you get better results).
    Also there are a lot of settings that give you a better result but takes longer to encode. If you are not trying to jam a bunch of videos onto a DVD and you can have a high bitrate at or above 6 Mbps I would recommend trying CBR encoding it should cut encoding time in at least half and I bet it will even look better.
