Activity › Forums › Apple Final Cut Pro Legacy › Hi Jerry, Need help.
  • Hi Jerry, Need help.
    Posted by Craig Alan on March 16, 2008 at 8:24 pm
    I’m a Video production teacher.
    We recently bought the latest FCP suite academic.
    Had FCP HD suite. Didn’t get a replacement disc in time to upgrade to universal 5.1. (all the originals were stolen/by the time I found the original order with PO #, it took too long for apple to send replacement disc).
    Trying to set up the 4.5 suite on external HD as suggested in your first Cow Mag article.
    On that drive
    I have 10.3.9 installed.
    I have the 4.5 FCPHD suite installed.
    All apps will launch and I have serial numbers for software.
    Trying to get Quicktime 6.5.2 installed.
    Trashed everything called quicktime from that system.
    When I run the quicktime 6.5.2 installer the drive has a red ! on it and it says I have an older version of quicktime in there so it won’t let me install.
    I tried repairing permissions. Rebooting. No luck.
    Any suggestions?
    The drive is attached to a G4 running 10.4.11 and quicktime 7.4.1. But I am booting from external drive.
    Craig
    OSX 10.4.11; Quicksilver Dual 1 gig; G5 dual 2.5 gig; FCP 4.5, 3.0.4; Sony camcorder vx2000/pd170;Canon xl2; Pana consumer cams; write professionally for a variety of media;teach video production in L.A.
    Craig Alan replied 18 years, 6 months ago 2 Members · 2 Replies
  • Zane Barker
    March 16, 2008 at 11:06 pm
    We will need you to do a bit of clarifying for us.
    [Craig Alan] “We recently bought the latest FCP suite academic. “
    The latest FCP Suit is FCS 2 which includes FCP 6.
    [Craig Alan] “Trying to set up the 4.5 suite on external HD”
    So which version are you truing to use the old 4.5 or the new 6.
    [Craig Alan] “I have 10.3.9 installed. “
    FCS2 and FCP6 requires at least OS 10.4.x
    [Craig Alan] “When I run the quicktime 6.5.2 installer the drive has a red ! on it and it says I have an older version of quicktime in there so it won’t let me install. “
    The new FCS also requires quicktime 7, which is one reason wit wont work with 10.3
    Please clarify what version exactly you are trying to install.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Craig Alan
    March 16, 2008 at 11:32 pm
    Hi Zane:
    It’s the older production suite I’m having problems setting up. We have one license for it and one license for Final Cut suite 2. So I’m setting up one where I want OS X 10.3.9; the original suite with FCP HD 4.5 and the other apps and QuickTime 6.5.2.
    What’s weird is if I run the latest QuickTime 7 installer it says the software has been successfully installed but it does not show up after the mandatory restart. FCP still launches and I don’t get an error message about QuickTime not being there. The 6.5.2 reinstall won’t work nor will the 6.5.2 installer.
