Activity › Forums › Adobe After Effects › Hi… i need some help with clouds
Posted by Mohit Woody on April 22, 2007 at 3:48 pmHi… i hv a footage in which the last shot has camera panning to sky// i wanna show something written on sky as if its written with clouds.
any help or info towards right dir is appreciated.
thanks guys!!!Woody
Majorasshole replied 19 years, 4 months ago 3 Members · 3 Replies -
Darby Edelen
April 22, 2007 at 7:45 pmWell I think there’s an animation preset for this using Trapcode’s Particular. If you don’t have access to that then I’d recommend playing with fractal noise using a pre-comped text layer as an alpha matte and a stroke effect to reveal it. This will take some definite tweaking to get a decent effect though. I haven’t tried it myself so I don’t have details for you, but it should give you an idea.
Darby Edelen
April 22, 2007 at 8:42 pmHere’s a sample I made in about 5 minutes using the technique I suggested above:
https://video.google.com/videoplay?docid=-5791548318456683085
The final comp has one pre-comped fractal noise layer, one pre-comped text layer and a solid with a ramp for the background.
The text layer is blurred slightly in the pre-comp and revealed over time using a stroke in the final comp. It has a Compound Blur and Displacement Map applied that reference the Fractal Noise pre-comp, then the text layer is used as an alpha matte for the Fractal Noise… and that’s about it.
You could add additional effects to give the text a sort of a ‘floating away’ kind of look.
Majorasshole
April 23, 2007 at 6:39 amyou can also just paint it in photoshop if it doesn’t need to animate
