Hi Guys
Hi Guys
I am having a problem with scan lines on footage that was shot on an EX3.The footage was shot and cut on HD 50i
and imported to final cut pro via xdcam transfer.
my final cut project is finished and exported using export quicktime movie, Apple Prores DV Pal
Now I am using encore for my menu etc because it is a preference for autoring.
After the DVD is transcoded and burnt it plays fine well but has terrible scan lines.
What is the best way to sort this?
Should I use compressor to export it as an m2v?? using the 90min preset?Thanks in advance for the help
