Activity Forums Live Events & Streaming Hi AVStumpfl WINGS users!
  • Hi AVStumpfl WINGS users!
    Posted by Maxim Moisseev on February 12, 2009 at 5:26 pm
    I’ve read the entire documentation and still don’t get one thing.
    If I need to set up a multidisplay show, do I need additional PCs running in slave mode, or I can use Triple-Head as with Catalyst?
    Thomas Leong replied 17 years, 7 months ago 2 Members · 1 Reply
  • Thomas Leong
    February 13, 2009 at 4:46 pm
    Hi Maxim,
    Using a Slave PC for each Display controlled by a Master PC is the ideal solution. But if resources are limited and your single PC has the oomph to handle the media playing at full frame-rates without hiccups, then you could use only that single PC (Master) as a Slave as well. This single PC is of course equipped with a triple-head graphics card (does any exist???). I use dual-head cards, but have not found a triple-head card yet.
    With a triple-head gfx card, you then only need one licence key to run a 3-screen multi-display show with Wings. Note that by a triple-head graphics card (if any exist), I am not referring to the Matrox TripleHead2Go device which works differently.
    If you want to learn further how to set-up a 3-display show, I suggest we take this off-line and I can step you through it, perhaps with some screen captures to illustrate. (But I’m having early nights and very early mornings with a full day outdoors till this Sunday…so you’ll have to be patient). Else, perhaps Alex can help instead.
    Thomas Leong
    tleong49 at streamyx dot com
    https://www.multidisplays.freeforums.org (for Wings specific questions)
