Activity Forums Apple Final Cut Pro Legacy Hi-8 and 8mm vid to digital conversion for broadcast
  • Hi-8 and 8mm vid to digital conversion for broadcast
    Posted by Sparxie on July 12, 2006 at 5:23 am
    Got some Hi-8 and 8mm vid shot on a Samsung VP-L300 camera in NZ recently.
    > Band performances.
    > Want to use some for Music Vid hopes to be on cable or better.
    > A friend has a Mac digitising setup and a Canopus something or other
    > filter to “clean it up” as my mate said – but he is still learning also.
    > Can anyone give me some more background or point to me recent posts re
    > similar/same?
    > What settings should we be using?
    > Any views about Final Cut Pro as our tool plus After Effects trial version?
    > Have been filing posts but no time to read for a while.
    > regards
    > Lorraine B at PCM
    Sparxie replied 20 years, 2 months ago 2 Members · 2 Replies
  • Thaxter Clavemarlton
    July 12, 2006 at 1:03 pm
    Sorry, but there is no entry-level unit that will “clean up” the quality of home video tape to “broadcast quality” level.
    The footage you have now will look the same after it is put into the computer.
    Unless noisey, low-resolution images are what you WANT (and sometimes, “for effect” you do),
    the music video will not look “clean” if your source tapes are not.
    One-chip camcorders and analog tapes are not even “close” to the same quality of 3-chip digital units.
  • Sparxie
    July 13, 2006 at 12:50 am
    Thanks Thax
    Thanks for reply – my first post to this forum – referred from DLF colleague.
    A lot of the footage is “atmospheric” to put it kindly! But some is quite good.
    I recall people using Hi-8 for docos and they went to broadcast some years back. So if original is ok then will be ok for broadcast too?
    Otherwise will use it as a “style” as you suggest
    My friend is using a Canopus filter and I thought he meant it would tidy up the general glitches of analogue as opposed to any improvement on my original footage.
    Any extra elucidation would be appreciated and thanks again for your reply
    regards
    Sparx
