Activity Forums Canon Cameras HG20: Progressive Segmented Frames?
  • HG20: Progressive Segmented Frames?
    Posted by Nayeli Garci-crespo on March 13, 2009 at 7:09 am
    Does anyone know for sure if the HG20 records progressive segmented frames or equivalent when set to PF24 or PF30? In other words, even if these are recorded into a 60i stream, after removing pulldown will you get true progressive frames, composed from fields that were from the same instant in time (aside from the rolling shutter issue)?
    -Nayeli
    Nayeli Garci-crespo replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
