Activity › Forums › Apple Final Cut Pro Legacy › Hey! Where’d Ctrl & V go?
  • Hey! Where’d Ctrl & V go?
    Posted by Alex Kuzelicki on July 25, 2008 at 2:56 pm
    Hi there,
    I’ve been using Final Cut Pro for many years now and I’m a big fan of the using Ctrl & V keys to quickly lay down cuts on the fly.
    Today, however, my Ctrl & V key combination suddenly doesn’t work!
    What the…?
    Just stopped working, just like that. I have no idea why. There must be something I’ve pressed or activated somewhere, somehow, but I have no idea what.
    Perhaps someone might be able to help me? I’m stumped.
    Thanks in advance,
    ALEX
    Alex Kuzelicki replied 18 years, 2 months ago 2 Members · 3 Replies
  • Psehn429
    July 25, 2008 at 3:07 pm
    Check under “Tools” > “Keyboard Layout,” > “Customize.” Under the “ctrl” tab you’ll find an icon on the V button. If your “cut” icon isn’t there, find it under one of the drop down carrots on the right and drag to replace it. I think you’re looking for “add edit”, which is under the Sequence menu.
  • Alex Kuzelicki
    July 25, 2008 at 4:23 pm
    I have just purchased a Mac Pro with and Io HD. Can anyone advise me on what would be the best type of internal hard drive to perches for HD editing? I’m planning on purchasing 2 X 1 TB internal drives.
    Adam
    Mac Pro
    Mac OSX 10.5.3
    Processor 2 X 2.8 GHz Quad-Core Intel Xeon
    Memory: 8 GB 800 MHz DDR2 FB-DIMM
  • Alex Kuzelicki
    July 25, 2008 at 4:39 pm
    Problem solved.
    It turned out that I had turned off Auto Select on the track I was trying to use Ctrl & V on. Der.
    Thanks to you both. Help very much appreciated. Saved me lots of frustration.
    Cheers,
    ALEX
