Activity Forums Apple Final Cut Pro Legacy Hey I need some ideas
  • Hey I need some ideas
    Posted by Santiago Gonzalez hoch on July 3, 2010 at 4:42 am
    Hi all i have a question ore a problem that i need to fix some how i have 23 .mov files that I have to burn on to DVDs. Now I know how to create a normal m2v file with its Ac3 file for DVD studio pro and it looks grate. But I need them to look grate in 20 meter by 13meater screen!!!!! (Projected) and I cant afford a blu-ray burner or a 35mm transfer (I’m in México its hard to find or buy) I tried to burn a HD DVD using the built-in presets in compressor but so far no DVD player, blu-ray disc player or laptop (except Mac) can read it. (what ii think is happening is that the bit rate is way to high for any of these I’m not sure though because blue ray discs I assume are faster or larger bit rates than dvds). So my question is…. Is there a way to burn an HDDVD that a normal dvd player Blu-Ray player can read and reproduce?????……… or is there a way to simulate Full HD in SD?????? Please help me I beg
    Bret Williams replied 16 years, 2 months ago 4 Members · 11 Replies
  • 11 Replies
  • Steve Eisen
    July 3, 2010 at 3:34 pm
    Roxio Toast Titanium 9 or 10 with the BD plug-in may be able to help you.
    Burn your sequence to Blu-Ray. If you can’t afford to buy a Blu-Ray burner than that’s not an option.
    If your sequence is 20-30 minutes, you can burn your sequence onto a standard DVD (AVCHD format) that will play on a Blu-Ray player.
    HD DVD has been discontinued. The options in DVDSP have no effect.
    Some standard DVD players have upscaling capabilities that do look good on big displays.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Bret Williams
    July 3, 2010 at 9:32 pm
    I’m curious about this AVCHD thing. Can you elaborate? I’d love to make a Blu ray disc with standard DVD burner of my generally 15 min corporate productions.
    And Aldo,just because it’s going to be big doesn’t mean it needs to be hd. Depends how close the audience is. Think billboards. They don’t look that amazing 5 feet away.
  • Steve Eisen
    July 3, 2010 at 10:01 pm
    You will find more information in Bruce Nazarian’s book “Fast Path to Blu-Ray.”
    https://www.thedigitalguy.com/
    Steve Eisen
    Vice President
  • Bret Williams
    July 4, 2010 at 1:59 am
    Surely I don’t need to spend $15 to discover this information.
  • Steve Eisen
    July 4, 2010 at 3:50 pm
    Then Google for free!
    Steve Eisen
    Vice President
  • Sohrab Sandhu
    July 4, 2010 at 7:48 pm
    Toshiba still has a few HD dvd players left in the market. See if you can find one somewhere.
    2.66 GHz 8-core, ATI Radeon HD 4870,
    FCS 3, AJA Kona Lhi
    “The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen.” — Carl Ally
  • Santiago Gonzalez hoch
    July 5, 2010 at 12:02 am
    i understand that point but when your audience is 6 ft from a 20mt screen ya kind of want to have a hi def resolution especially when there is text subtitles or logos involved you tend to have a fathering affect on the edge of the logos or text which is part of the reason I want to burn in HD
    I am trying out the burn your sequence onto a standard DVD (AVCHD format) that will play on a Blu-Ray player.
    But I don’t understand how that Works do I need to set it up some way in compressor???? Or in FCP or After Effects
    my sequences are about 12 to 15 min long so Im guessing it should work????
    July 5, 2010 at 12:03 am
    thx
  • Bret Williams
    July 5, 2010 at 3:56 pm
    So what are you searching for Dave? I tried but all I find are threads about burning blu-ray discs in toast that are images, or have been encoded with toast, etc.
    I was looking for info on burning AVCHD files onto standard DVD-R that plays in blu-ray player. Sounds intriguing. Brief google attempts were a little hazy, but the data is out there. I just have work to get done in the meantime. 🙂
  • Steve Eisen
    July 5, 2010 at 10:29 pm
    From Roxio Toast Titanium 10 manual:
    To make a High Definition DVD:
    1. At the top left of the Toast window, click Video and choose the Blu-ray
    Video project
    2. Choose optional disc settings:
    The disc settings and options available are identical to those available
    when creating a DVD or Blu-ray Disc™. For more information on
    these options and settings, see Making a DVD or BD Video Disc.
    3. Add your HD video files to the disc by dragging and dropping them
    into the Content Area from your hard disk or the Media Browser.
    4. On the disc gauge in the bottom right hand area of the window, select
    DVD or DVD DL as your target media type.
    5. Insert a blank, recordable DVD
    6. Click the red Record button, choose a recorder from the list, and
    configure recording options, such as Number of Copies.
    7. Click Record to continue.
    Toast displays a progress bar and status information as it records your disc.
    Steve Eisen
    Vice President
