Activity › Forums › Apple Final Cut Pro Legacy › Hey David Weiss
Hey David Weiss
Posted by Chris Borjis on May 1, 2007 at 2:07 amJust wanted to let you know, I was editing a 3 minute industrial today with nothing but large (2k and bigger) stills.
On my pro crt monitor I saw aliasing and pixel shifts in dissolves (as I had discussed with you before)
These all showed “Green” on the timeline for realtime playback.
I did a render all (not option+r as it did nothing) and now everything looks great!
I did not know it was sort of a proxy that fcp was doing.
So I guess my system is ok! 🙂
Chris Borjis replied 19 years, 4 months ago 3 Members · 8 Replies -
Jeremy Garchow
May 1, 2007 at 3:16 amYou have to go to your render all and render selected menus and put a check mark by all the options, including full. Then option-r will render everything that needs to be rendered including full rt effects.
Jeremy
David Roth weiss
May 1, 2007 at 5:17 amChris,
Glad you’ve got animated stills cooking now. Its the simple things that get ya… I couldn’t imagine what the trouble was. All I know is, I’d certainly be editing on some other system if I couldn’t do a great job animating stills.
DRW
Chris Borjis
May 1, 2007 at 4:09 pmwell i think its a bug in compressor, because this aliasing uglyness would show itself if i went directly from the timeline to compressor for DVD mpeg video (and we all know how buggy that can be at times)
Very much looking forward to FCS 2.
Thanks for the tips Jeremy! 🙂
David Roth weiss
May 1, 2007 at 4:32 pmI don’t think so, cuz I am using Compressor on everything and I can create DVDs without the aliasing when authored in ReelDVD. On the other hand, I’m beginning to suspect that my DVD burner in my MAC has always been a lemon, so who knows what abberations that could be causing.
Jeremy Garchow
May 1, 2007 at 5:03 pm[David Roth Weiss] “I don’t think so, cuz I am using Compressor on everything and I can create DVDs without the aliasing”
Agreed, that version of Compressor are you running, Borjis?
Chris Borjis
May 1, 2007 at 7:16 pmWow David your still using Reeldvd? Me too!
I think thats when I first met you online, at the dvd authoring forum.
I’m running compressor 2.01
David Roth weiss
May 1, 2007 at 7:45 pmYep, that’s how we know each other, from the old days when DVD creation was still a big mystery.
I still think ReelDVD, dispite certain limitations, creates the most rock solid DVDs of any of the desktop authoring apps. I never get DVDs back that don’t play…
Chris Borjis
May 2, 2007 at 4:21 am[David Roth Weiss] “I still think ReelDVD, dispite certain limitations, creates the most rock solid DVDs of any of the desktop authoring apps. I never get DVDs back that don’t play…”
So True! 🙂
