Activity Forums Adobe After Effects HEROES WANTED: Fading Away the End of A Box For Lower Third Purposes
  • HEROES WANTED: Fading Away the End of A Box For Lower Third Purposes
    Posted by Asia Taylor on April 5, 2013 at 4:13 pm
    Hello Hero!
    Hopefully you can save me. I am trying to create an interesting lower third by using a motion background cropped into a box and then on top of it the interviewee’s title. I am using Premiere CS6.
    Here’s the problem..
    I want the right side of the cropped box to fade away slowly instead of ending in a hard box line. An example of what I want is in the screen shot below. I created this however in the Title tool box with the gradient feature and lowered the opacity of one of the gradient markers.
    I can not duplicate this in the title tool obviously due to the fact that you can’t import video into the title tool window. A screen shot of my current lower third is below.
    The biggest problem is that I only want to fade away ONE side of the box and not the top or bottom.
    What I have tried:
    Garbage Matte
    Track Mattte
    Blur Edges
    So how would you suggest I do it? I’d like to get this accomplished in premiere but I also have after effects and am willing to try and get it done in there if needed.
    Anxiously Waiting,
    – Lois Lane
    Asia Taylor replied 13 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Anthony Marzilli
    April 5, 2013 at 6:15 pm
    Dave is right but I will at least give you a tool to try to figure it out. Look up Linear Wipe and feather. Those two things can get you there but there are more steps in the process.
  • Joseph W. bourke
    April 5, 2013 at 6:32 pm
    While what Anthony says will work, and will probably get you there the quickest, the best way to do it, in my estimation, is to create your lower third blank in Photoshop, then import the layers, and do whatever animations you need (if you need them) in AE. This is just my preferred workflow, since it gives me the ability to go back and forth between AE and PS as I need to.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Anthony Marzilli
    April 5, 2013 at 6:39 pm
    To make this possibly even quicker you should just render out the Motion Background video out of after effects with the linear wipe and feather with an alpha channel. That way you can just add all the text in premiere and not have to keep jumping back and forth between AE and Premiere.
  • Joseph W. bourke
    April 5, 2013 at 6:45 pm
    Oh…I’m with you there, Dave. I create my “template” – shapes, borders, boxes, lines, elements, etc. in PS, then I use them to cut and mask the animated elements I create in After Effects. I haven’t done a still lower third system in about 10 years. It’s all about the motion…
    Joe Bourke
    Bourke Media
  • Greg Neumayer
    April 5, 2013 at 8:02 pm
    You’re in the After Effects forum, so I’m assuming you’re looking for an after effects solution. The good news is that you’re making it more complicated than it needs to be. Here’s what I would do, as step by step as I can think to describe.
    1. Create the following layers: Layer 1: Your text, Layer 2: A colored solid, set to the size you want.
    2. Draw an over-sized round or square mask on top of your colored solid so that you’re splitting it in half. Imagine cutting a banana (your solid) in half with a large Tupperware bowl (your mask). This mask will extend quite a bit beyond your window edges.
    3. Change the mask feather to be softened to your liking. Start with maybe a feather of 400px.
    (4. If desired, animate the “wipe on” of the color bar by animating the position of your mask.)
    Antifreeze Design
    https://www.antifreezedesign.com
  • Walter Soyka
    April 5, 2013 at 8:50 pm
    [Asia Taylor] ” I’d like to get this accomplished in premiere but I also have after effects and am willing to try and get it done in there if needed.”
    The Premiere Pro forum [link] would be a better place to get a Premiere-specific answer, but I’ll give it a go here anyway.
    You can adjust the scale and position of a clip by selecting it on the timeline and adjusting its scale and position properties in the Effects Control window.
    Add the Crop effect (Video Effects > Transform) for hard-edged cropping.
    Add the Linear Wipe effect (Video Effects > Transition) to fade just the one edge. Adjust the “Transition Completion” parameter, “Wipe Angle” and “Feather” to taste. They can all be animated.
    Walter Soyka
  • Asia Taylor
    April 5, 2013 at 9:02 pm
    I would consider myself on an intermediate level so I believe I would understand your steps or at least be able to figure it out.
  • Asia Taylor
    April 5, 2013 at 9:13 pm
    Dave LaRonde,
    I would consider myself on an intermediate level of After Effects. Most of your vocabulary should be familiar and if not I’ll look it up.
