Activity › Forums › Apple Final Cut Pro Legacy › Here’s an interesting potential gotcha
  • Here’s an interesting potential gotcha
    Posted by David Roth weiss on November 30, 2010 at 12:26 am
    A client working on their first HD project cut a load of stuff in an HD sequence with the field dominance reversed, i.e. set improperly to “Lower.” You can’t rectify that by simply changing field dominance in the original sequence, and quite by accident, I found that you can’t simply copy all the clips into a new properly setup sequence either, at least not without performing an extra step in the process.
    The secret is:
    a) first copy all clips from the sequence with the improper field setting
    b) open a new sequence with the proper settings
    c) before pasting the clips into the sequence you have to first set the field dominance to “none,” then paste, then change the field dominance back to “upper.” If you don’t do this step, field order is not properly interpreted and the video will look like absolute gunk.
    BTW, this is tested and repeatable. Try it out for yourself… More importantly, remember it for that one time a client gives you something to online in a sequence that has the fields reversed.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
    David Roth weiss replied 15 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 30, 2010 at 2:03 am
    I haven’t seen that. When I copy and paste into a CORRECT sequence setting, I’ll notice that the clips have a SHIFT FIELDS filter…I just delete all those and I’m good.
    Shane
  • David Roth weiss
    November 30, 2010 at 2:10 am
    You pinpointed it Shane…
    When the client put the material in a seq. with reversed fields it added the shift fields filter– when I pasted into a seq. with fields set to “none” it removed the shift fields filter — then when I reset to Upper it just works right.
    THNX, glad we clarified that one…
    DRW
    David Roth Weiss
    Los Angeles
