Activity › Forums › Apple Final Cut Pro Legacy › Here’s a nice MacPro 5th hard drive solution
  • Patrick Sheffield
    August 28, 2007 at 7:27 am
    Nice, but I just used a 5.25 -> 3.5 adapter bracket, a SATA cable to the additional SATA connectors on the motherboard and a sata power cable from the optical power connector.
    cost, less than $10 bucks…
    Patrick
  • Sean Oneil
    August 28, 2007 at 4:08 pm
    [Patrick Sheffield] “Nice, but I just used a 5.25 -> 3.5 adapter bracket, a SATA cable to the additional SATA connectors on the motherboard and a sata power cable from the optical power connector.”
    Ditto. I do the same thing. So I get a 4-disk RAID plus my system disk.
    I hear there are also 5.25″ brackets that can hold 2 drives, so you could add a sixth as well.
