Activity › Forums › Adobe After Effects › Here’s a challenge: Stabilising a rotating shot…
  • Here’s a challenge: Stabilising a rotating shot…
    Posted by Amir Bazrafshan on April 13, 2012 at 4:00 pm
    hello all,
    I have a shot that needs stabilising – but I have tried AE, FCP, Mocha, Motion – all with no success.
    Here is a brief description of the shot, so you know what I am facing.
    It’s a simple CU profile (character looking off camera), which then moves behind the character so we see what he is looking at, ending on an over the shoulder shot.
    The issue is that there is not one single part of the frame that is always in shot, so there isn’t a fixed point for the software to track.
    If anyone has any ideas, they would be most welcome – this is the last shot of the film, so I’d love it to be as good as possible.
    Cheers
    Amir
    Chris Wood replied 14 years, 5 months ago 4 Members · 5 Replies
  • Walter Soyka
    April 13, 2012 at 4:47 pm
    You mentioned that you tried AE — have you tried CS5.5’s Warp Stabilizer?
    Walter Soyka
  • Darby Edelen
    April 13, 2012 at 4:52 pm
    What version of After Effects are you using? CS 5.5’s Warp Stabilizer should be able to help with this shot.
    Or if you have access to The Foundry’s Camera Tracker, there’s a workflow you can use to stabilize footage with that.
    Otherwise I think the solution may be painful. For example, you can move the point tracker to focus on a new feature without moving its attach point. You could select new track features as the old ones leave the frame. However, this is complicated by parallax, things at different distances from the camera will move at different rates. Still, there may be a potential solution there.
    Darby Edelen
  • Amir Bazrafshan
    April 13, 2012 at 5:49 pm
    hey thanks for the response – no, i dont have access to that but will look into it for sure.
  • Amir Bazrafshan
    April 13, 2012 at 5:50 pm
    hey, cheers for the heads up on this – i will look into those.
    fingers crossed!
  • Chris Wood
    April 17, 2012 at 11:35 pm
    Andrew Kramer posted a tutorial for VCP where I recall him enabling a tracker to track a tracker.
    It’s the set extension tutorial he does where he composites a few old stone castles into the background.
    The camera moves from a shot of the ground, way way way off horizontally and then ends up on its target. He just parents one tracker to the other in some fashion and it seems to work.
    You would probably have to daisy-chain a bunch of trackers in this way, but as long as you give your trackers something good to grip to, you should be alright.
    You could also look into 3D matchmoving such as Boujou / Syntheyes as, though they are primarily 3D trackers, they can do 2D functions such as stabilization.
