Here is a Strange one
Hey Herd!
I am running into a strange issue with frame rates on DVCPro HD clips. Here is the summary:
_ shooting on Panasonic cameras at 24/30 (59.94)
– Loading footage from tape through SDI/ AJA LH cards from Panasonic AJ-1400
– e, we notice when looking at clips directly in Quicktime that the famerate is listed at numbers slightly off like 29.92, 29.96 etc. (see attached pic)– in FCP the same clips indicate they are 29.97 in the item properties, and seem to play back fine.
– it seems to be random.. tested this by reloading clips that were originally listed as 29.97 in QT
– loading to Avid Unity partitions normally but have tested with local drives too.
– also have tested loading via Firewire with same resultsQUESTION: Is this just some QT bug or can this be a real issue with the files?
System specs are:
Power PC Dual 2.6 ghz
4 GB ram
OSX 10.4.11
QT 7.5.5
AJA 6.0.3Liam Lawyer
-editor-
