Activity Forums Apple Final Cut Pro Legacy Help….Rendering Problem
  • Help….Rendering Problem
    Posted by Brian on October 7, 2005 at 6:31 pm
    Hopefully someone here has encountered this problem and knows a good fix for it. When I try to render anything in Vegas 4.0d, it comes up with an error msg and then closes out the program. It only happens whe I try to render out as an MPEG2, but MPEG1 and AVI are fine. The error msg that comes up states:
    An error occurred during the current operation
    An exception has occurred
    Sonic Foundry Vegas 4.0
    Version 4.0d (Build 205)
    Exception 0xC0000005 (access violation) READ:0xA0238 IP:0xA0238
    Thread: GUI ID=0x768 Stack=0x134000-0x140000
    Registers:
    EAX=00000000 CS=001b EIP=000a0238 EFLGS=00010212
    EBX=00000001 SS=0023 ESP=00134930 EBP=073c97f0
    ECX=77d4e324 DS=0023 ESI=00000012 FS=003b
    EDX=7c90eb94 ES=0023 EDI=00000000 GS=0000
    Bytes at CS:EIP:
    000A0238: .. .. .. .. .. .. .. .. ……..
    000A0240: .. .. .. .. .. .. .. .. ……..
    Stack Dump:
    00134930: 000A0238 00040000 + 60238
    00134934: 0013BDC0 00040000 + FBDC0
    Any assistance anyone could provide would be appreciated, as I am trying to render a project I have finished. Is there a particular reason why it would only happen when I try to render out as an MPEG2, and not any other format? Thanks!
    Brian Pitt replied 20 years, 11 months ago 2 Members · 1 Reply
  • Brian Pitt
    October 7, 2005 at 6:56 pm
    you might want to post this in the Vegas Forum.
    Brian
