Activity Forums Boris FX Particle Illusion Help…Problems with PI
  • Help…Problems with PI
    Posted by Choc_tpot on March 25, 2006 at 4:28 pm
    Help!!!
    Im getting an error message everytime I try and open PI.
    It says “Runtime error! abnormal program termination”.
    I’ve tried reinstalling but nothing seems to be working.
    Any ideas?
    Many thanks
    Kev
    Elvis Deane replied 20 years, 5 months ago 3 Members · 3 Replies
  • Alan Lorence
    March 25, 2006 at 7:00 pm
    Use “reset default settings” in the Start – Programs – particleIllusion menu.
    If that doesn’t work, your “default” library is corrupted (but this is not likely since you reinstalled).
    Alan.
    wondertouch
  • Choc_tpot
    March 27, 2006 at 5:39 pm
    Thank you. That worked. However, now I have another problem. I have a library of all my most commanly used emitters but since I fixed that last problem I haven’t been able to open it. I get an error message that reads
    “an attempt was made to access an unnamed file past its end”.
    Any ideas???
    Once again, your help is much appreciated.
  • Elvis Deane
    March 27, 2006 at 7:39 pm
    Check in your Library Backups folder if there’s a backup copy saved. It’ll have a funny extension on the end, but you can just change it to .il3 and it should open up.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
