Activity Forums Apple Final Cut Pro Legacy Helping slight jump cuts
  • Helping slight jump cuts
    Posted by Chris Poisson on February 8, 2008 at 3:57 pm
    I am finishing up a talking head video, the subjects are parents who lost young kids to cancer.
    The client was VERY selective about what they say and when, so there are a few jump cuts as they speak. If they are between thoughts, a dip to black fixes it fine, or I can put b-roll or stills over them. But there are one or two where the jumps come in the middle of a thought, so I’m stuck with them.
    Any wisdom on this kind of thing?
    Have a wonderful day.
    Chris Poisson replied 18 years, 7 months ago 5 Members · 5 Replies
  • Jeremy Garchow
    February 8, 2008 at 4:15 pm
    Set up the gimmick early. If you are going to go with jump cuts, make a style of the piece so the audience will accept it instead of rejecting it when it happens “all of a sudden”.
    Find more Broll/Pictures, even if it isn’t ‘see say’.
  • Adam Taylor
    February 8, 2008 at 4:18 pm
    depends on the context….
    if your edit is actually changing the meaning of what was said and you don’t want it be known that is what you’ve done, then cover the offending cut, but be as subtle as you can with choice of covering shot, maybe using a couple of shots as a relevant montage. A single shot will usually look obvious as a cover-up.
    If you would rather be honest and say yup, we cut this because they droned on for hours – then use a subtle mix. People will know its been cut, but they also know that as you have visually admitted it, then chances are you’re not trying to pull the wool over anyones eyes.
    well thats how i feel about those kinda cuts…..
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • Greg Ball
    February 8, 2008 at 4:21 pm
    I tend to use white flash frames, or there are some really cool glows built into FCP that you can use. But as someone else said earlier, you need to determone the style, look, and feel you want and then add effects accordingly. Try not to overuse them though.
  • Del Holford
    February 8, 2008 at 4:32 pm
    I think the conventional wisdom of soft cuts (3 -6 fr dissolves) combined with dips to black for complete thoughts would be sensitive to the subject matter. Even though you soft cut in the middle of the thought, continuing dips to black at the end of those thoughts will keep a smooth flow. I suspect you have limited B-roll and photos so you would want to use those where they put forward the story rather than randomly dropping them in as cover for the jump cuts.
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
  • Chris Poisson
    February 8, 2008 at 5:52 pm
    Del,
    Great advice, you read my mind, I don’t have a lot of photos, and I agree about how and where to use them.
    Thanks to all, great ideas.
