Activity › Forums › Apple Final Cut Pro Legacy › HELP…Editing Newbie
HELP…Editing Newbie
Posted by Joe Breaux on May 10, 2008 at 10:16 amSo I have several clips with multiple takes… I’m trying to combine part of one clip to part of another clip seamlessly; so it looks like one take… I’m wondering what are the best tools to use in final cut to solve my problem… or is this not fixable?
Thank you,
Joe
David Roth weiss replied 18 years, 4 months ago 4 Members · 5 Replies -
Richard Harrington
May 10, 2008 at 1:56 pmUmm… its called another angle or B-roll
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Dunwoody Lampton
May 10, 2008 at 2:34 pmWhat kind of shot are you coming from?
What kind of shot are you going to?
Are all of your clips from the same angle?
Do you have cutaways to go to during the transition
from Clip A to Clip B?Are you trying to match-frame from Clip A to Clip B?
Is there sound involved or just video?
What is your subject(s)?
Without more information it’s hard to offer suggestions.
Offhand, it sounds like you are trying to match-frame
between two nearly identical clips, which is a challenge
whether you’re editing tape-to-tape or non-linear.
If this is the case, then 94% of the work for the desired effect
should have been done when setting up your shots in the field, in order to facilitate easier match-frame editing later. If this is, indeed, what you are trying to accomplish, then be aware that neither Final Cut nor any other NLE application offer magic solutions to match-frame editing. The “magic” is applied in the field, not the edit suite. -
Richard Harrington
May 10, 2008 at 3:04 pmWhite Flash (Dip to Color)
Joe Breaux
May 10, 2008 at 4:51 pmHey Guys,
Thanks for the info and sorry for not enough information…
The difference between the 2 shots is that the actor is not exactly doing the same thing…
For example Clip A he’s closing his phone to fast and Clip B he takes a little longer to close his phone… He is not in the exact same position in the shot… but I like to combine the 2 clips seamlessly…
I think I am trying to match frame and there is no sound involved…I hope this is enough information…if not let me know…
Thanks for your helpJoe
David Roth weiss
May 10, 2008 at 7:11 pmEvery shot is different, but trying a perfect match frame edit is often the thing that gives away continuity problems between shots rather than fixing them.
The secret can be as simple as cutting on action where the A-side of the cut and B-side don’t actually match, but where the B-side is a progression farther along in time than the end of the shot that proceeds it.
For example, when a guy suits up for combat, we can easily jump cut effectively and without distraction from zero weapons and no body armour to fully armed and suited up, all without a single match cut, so long as each shot visually exhibits progress. Cutting two standard shots together with normal action is quite not as easy as rapid-fire montage of quick cut jump cuts, but I think you’ll find the same principles do apply.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
