Activity Forums Adobe After Effects Help!about 3D perspective distortion
  • Help!about 3D perspective distortion
    Posted by Joe Chao on May 10, 2005 at 2:35 am
    I make a 3D sence in AE.I want a layer to move in a 3d space,but I don’t want it be distorted because perpective reason.So I make the layer looking at the camera to avoid such thing.But It seems I failed.The layer keeps looking at the camera,but still being distorted. What’s wrong?What should I do?
    Any sugestion would be appreciated,and thinks in advance.
    My name is always misread as COW……..:)
    so I got this ID:
    friendcao2004@hotmail.com
    Joe Chao replied 21 years, 4 months ago 2 Members · 4 Replies
  • Graham Quince
    May 10, 2005 at 8:34 am
    Just to double-check: You’ve turned on auto-orient towards camera for your layer in 3D. set your player in 3D space and then you animate your camera to fly around, or are you flying your layer around?
    You have created a camera? You’re not using the active camera setting in the preview window? it’s a mistake i’ve made before and took ages to spot it.
    Graham
  • Joe Chao
    May 10, 2005 at 9:17 am
    Thanks a lot.
    I checked the both two points.But I still can not get rid of the distortion.I ‘m completely confused.
    so I got this ID:
  • Graham Quince
    May 10, 2005 at 2:32 pm
    ah i got it. i’ve just recreated your poect based on description. It’s down to the camera’s point of interest.
    What you need to do, is set a postion keyframe for your solid, copy it and paste it into the point of interest for your camera.
    Now no matter where you move your camera, your solid will always point towards it and you camera will always look at it.
    Graham
  • Joe Chao
    May 11, 2005 at 6:46 am
    Thanks ,but I have many solids in the sence.:(
    I found it has something to do with the camera’s point of interest too.And I found if If I chose a 200mm camera,the distorting will be weakened.
    so I got this ID:
