  • Posted by Ben Oliver on August 18, 2006 at 1:09 pm
    why is my final cut pro 5(all the updates applied, has been that way for a , when i try an export a full quicktime of my movie (4 hour long sequence, i’ve done it before) it tells me there is a file size error??? it happened when i tried to cut the file up into smaller pieces as well.
    need to render out a piece before the end of the day today…grr
    -ben
    Ben Oliver replied 20 years, 1 month ago 3 Members · 4 Replies
  • Randyp
    August 18, 2006 at 1:13 pm
    It may be a storage problem–not enough room. What drive is your QuickTime being render to? Is there enough room there for it?
  • Ben Oliver
    August 18, 2006 at 1:24 pm
    i iwas trying to render it to a raid….trying a different drive now.
  • Jim Martin
    August 18, 2006 at 2:33 pm
    make sure you are exporting to an HFS+ drive
    Jim
  • Ben Oliver
    August 18, 2006 at 4:49 pm
    yeah, i still don’t really know what the culprit was.
    i trashed prefs, updated the OS and QT, etc. and i exported to a local drive, before sending to the raid/server and it’s all good.
    -ben
