Activity Forums Apple Final Cut Pro Legacy HELP! Working with wave/multiple audio tracks/sequence settings
  • HELP! Working with wave/multiple audio tracks/sequence settings
    Posted by Dennis Mcelroy on February 10, 2008 at 1:01 am
    OK I’ll try to summarize this as best as I can.
    Large project with 17 audio tracks of production audio.
    -The audio files are .wav
    The project is DVCPro 720 p 60. The audio is 48k 24 bit.
    I worked with the material for a long time without any problems. I did NOT have to render my audio at any point. I could hear all seventeen tracks at once without the red render bar.
    In an act of sheer lunacy. I dumped my three settings files.
    (Final Cut Pro 6.0 Prefs.fcset,
    Final Cut Pro Obj Cache
    & Final Cut Pro Prof Cache)
    I went to re-open the project. Now in now way shape or form can I listen to all my tracks of audio (unless they are 8 tracks or less) without rendering them first. Any audio edit I do effects the sequence from the in point down to the end, and I have to re render every time.
    I’m pretty sure it’s a sequence setting and have been hacking away at it for hours. Any ideas on what would enable me to get this back the way I had it (being able to listen to all my audio without having to render.)
    AND PLEASE-I know I shouldn’t have that much audio on the timeline. I inherited this project from someone else and was working with it well up until I insanely dumped my settings. I am resistent to compressing tracks knowing the capability to work with all of them is there and that I have done it, and also feeling like I’m a sequence setting away is killing me!
    DM
    Dennis Mcelroy replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
