Activity › Forums › VEGAS Pro › Help with vhs conversion
  • Help with vhs conversion
    Posted by Michael O’connor on June 14, 2006 at 10:32 pm
    I have a client that needs to have a vhs promotional tape updated using the film from the vhs. What is the best settings or way to bring it in for the highest quality reproduction? I have canopus and vegas 4. It seems when I get it in to vegas there is distortion on the outside rim of the clip(s) so when I edit and then print to tape the quality loss is quite high. I know there is quality loss when transfering from vhs into vegas when it goes into avi but is there a “best” way for the best quality? Thanks for the help. Michael
    Michael O’connor replied 20 years, 3 months ago 5 Members · 7 Replies
  • 7 Replies
  • Stephen Mann
    June 14, 2006 at 11:59 pm
    You don’t say which Canopus product, but I’ll bet it’s not the ADVC-300 with TBC. The distortion that you describe says that the converter box was receiving a weak analog signal from the VCR. A better VCR would help as would a Time Base Corrector (TBC). Also, use s-video if possible. If you are using the composite or (yecch) RF connector, you are seriously compromising the quality from the beginning.
    Steve M.
    Stephen Mann,
    MannMade Digital Video,
    San Jose, CA
  • Michael O’connor
    June 15, 2006 at 12:53 am
    Thanks for the advice. It’s the ADVC-100. I’ll try S video. Michael
  • Michael O’connor
    June 15, 2006 at 1:53 am
    Tried the s-video but it appears s-video out of the unit is only for the dvd part. It is a new vcr / dvd record unit. I also have an older vcr / dvd unit and the back of it says s-video dvd only. Is there a way to do s-video with vcr?
  • Mike Kujbida
    June 15, 2006 at 2:13 am
    Try putting a mask around the outer edges of the clip to hide the defects.
  • Wayne Starick
    June 15, 2006 at 2:42 am
    If you have the Pixelan CreativeEase plugins, then CleanCrop will do wonders for this sort of artifact.
    https://www.pixelan.com/ce/features-cc.htm
    Wayne Starick
    If there is no Internet in heaven – I am not going!
  • Jim Prisby
    June 15, 2006 at 4:52 am
    I use a JVC SuperVHS VCR for my transfers. It has s-video out and a built in TBC. JVC VCRs are said to be very good at showing a clean video, so far I have found this to be true.
  • Michael O’connor
    June 15, 2006 at 6:58 am
    Thanks guys for all the suggestions. One is bound to do what I need. Happy editing! Michael
