Activity Forums Adobe Photoshop help with vanishing point export
  • help with vanishing point export
    Posted by Marcosh on October 23, 2007 at 11:07 am
    Hi there,
    I’m trying to export the VP data I created on a PSD file but I don’t have that option on menu inside the Vanishing point filter workspace…
    I went back to the Photoshop main interface and can’t find that option under EXPORT either.
    And that’s not my only problem. I’m trying to use the “option click” + drag shortcut to change the angle of a plane from its 90 degree default and that’s not working neither.
    Am I missing something?
    Btw, I’m using a full Professional CS3 package, with a Mac 10.4.8, Dual Quad…
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
    Jason Hare replied 17 years, 5 months ago 4 Members · 4 Replies
  • Richard Harrington
    October 24, 2007 at 1:55 am
    It is in the submenu of the Vanishing Point window (when filer is running)
    If you have the book Photoshop for Video… you can download a full tutorial from the book’s website
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Jason Hare
    March 31, 2009 at 12:40 am
    I am having the same problem as the original poster. I was trying to do a tutorial from this website when I discovered that when I click the submenu within the Vanishing Point window I do not have any export options.
    I am running Photoshop CS3 on a Macbook Pro 2.33g Intel Core 2 Duo with 3gig Ram.
    I tried reinstalling both After Effects and Photoshop but it has made no difference. The only options I have in the menu are:
    Show Edges
    Show Measurements
    Render Grids to Photoshop
    Allow Multi surface operations
    Clip operations to surface edges
    The last two options are greyed out.
    Hope someone can help!!
  • Andrew Dickinson
    April 3, 2009 at 3:04 pm
    I am having this same problem myself. I’d like to use the features for After Effects. But, it turns out you need Photoshop Extended to be able to export to After Effects.
  • Jason Hare
    April 12, 2009 at 1:37 pm
    Ah so that is the answer. What is the point of giving out half a filter I wonder?
    Thanks for the tip.
    Jason
