Activity Forums Adobe Encore DVD Help with Stretchy footage in Encore 2.0
  • Help with Stretchy footage in Encore 2.0
    Posted by Bluebirdx1976 on February 14, 2006 at 6:02 pm
    Looking for some help on this one! Encore keeps horozontally stretching my video assets that I import into the project.
    I’m exporting a Quicktime file from an AVID project using the H.264 codec. The dimensions of the image are 720 x 480 with an aspect ratio of (0.9) 4:3
    I then bring the asset into my project in Encore 2.0 and it looks horozontally stretched. In the edit transcode presets section where you can preview both
    the source and the output… the source is reading 720×480 and the output is the same, but when I click on the output tab the footage is stretched even further and
    the letterbox appears as if I’m dealing with 16:9
    How can I get encore to not mess around with the demensions of my assets?
    Thanks so much in advance!!!
    Bluebirdx1976 replied 20 years, 6 months ago 2 Members · 2 Replies
  • Joe Bowden
    February 14, 2006 at 7:23 pm
    Try using Interpret Footage on the clip and set it to .9 PAR; if that doesn’t work, then don’t use the H.264 codec…Encore doesn’t support it.
  • Bluebirdx1976
    February 14, 2006 at 9:14 pm
    Thanks for the advice! Tried the interpret footage option for 0.9 and this has no effect on the stretch happening in Encore DVD.. it’s still there.
    Here’s another thing that I discovered while troubleshooting…
    I can bring that exact same Quicktime file that Encore stretches into After Effects, export as mpeg2-dvd and bring both the original and newly created files into Encore.
    It’s still stretching the orignal file…but does not stretch the After Effects file…anyone know why this is?
