Activity Forums Apple Final Cut Pro Legacy help with sound
  • help with sound
    Posted by Alieninnovation on January 12, 2007 at 8:10 am
    hi,
    i’m not a bog sound guy so i would need some help on this one.
    we just got donw filming the high schools drama play.
    where the camera was approx. 10 feet away from the stage.
    so the sounds is a bit low and almost no highs (well depending on the dialog).
    what is the best to give the audio a bit of a kick. tunning up the gain just distorts it and i have not found a good eq setting.
    thanks for any tips.
    Toby Dalsgaard replied 19 years, 7 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    January 12, 2007 at 1:11 pm
    Sadly, the time for asking this kind of question was BEFORE the shoot.
    The audio should not have been recorded using only the on-camera mic.
    At the very least, there should have been mics placed on or susspended over the stage.
    “PZM”-type mics are sometimes used on the stage floor.
    Sometimes wireless mics are placed on the actors.
    Other times mics are suspended from the light-pipes above the set.
    Sometimes there are combinations of these… all mixed live by an audio technician.
    Recording theatrical presentations can require some creative microphone techniques and even then, it can be a compromise that needs some EQ and Noise-gate work in the edit.
    The audio you have now (recorded at a distance) is likely nearly 50% made up of unwanted room-reflections (reverb) and noise from the camera, audience members, and the air conditioning/heating.
    I’ll say that you should EQ down the lower frequncies and boost the mid-range, but no amount of EQ will fix the poorly-recorded audio track.
    Adding and adjusting the Noise-gate filter can make a difference… but it can also make matters worse, depending on the audio track you start with.
    Sorry.
  • Toby Dalsgaard
    January 12, 2007 at 4:16 pm
    Sadly you can’t bring out the kick in something that never had kick in the first place. Your question kind of like asking “I just aimed my camera straight at a solar eclipse with the gain at +6, how do I bring up the blacks”?
    My last ditch advice would be compression. You’ll bump up the gain a tad without distorting, but it’s not going to get “rid” of anything. If you spend some time tweaking it, it MIGHT make some of the more desirable aspects of the recording SLIGHTY…very slightly. But you’ll also be bumping up some crappy ones as well.
