Activity Forums VEGAS Pro Help with slowmotion!
  • Help with slowmotion!
    Posted by Raul Anghel on August 30, 2026 at 6:42 pm
    Hi everyone! I’m still getting the hang of VEGAS Pro and I was wondering if anyone could help me with something.
    I’m trying to make a smooth speed ramp where a clip starts at normal speed and then gradually slows down, but whenever I try using the velocity envelope, the transition feels kind of sudden.
    Is there a better way to make the speed change smoother, or maybe a specific setting I should be using? Thanks in advance!
    Silviu Negoita
    replied 2 weeks, 1 day ago
    2 Members · 1 Reply
  • Silviu Negoita
    August 30, 2026 at 7:39 pm
    Hi Raul! You can make it smoother by adding a few more points to the velocity envelope and changing the points to a smoother curve instead of having them change too quickly. You can also try adjusting the velocity values gradually, like 100% → 70% → 40% → 20%, rather than going straight from 100% to 20%.<div>If it still feels sudden, make the ramp longer. VEGAS needs enough time between the speeds for the change to feel natural.</div><div>
    </div>
