Activity Forums Adobe After Effects Help with Shatter
  • Help with Shatter
    Posted by Juan Obregon on April 26, 2006 at 8:37 pm
    Hello all
    I need to stop the shatter effect once it has exploded to be able to move the camera around the different pieces.
    I have lot of pict in one photoshop document they are on a grid of 20 acroos 10 down i used the same grid in black and white as acustom shatter map. the document or image explodes but continues to scatter I need it to stop (freeze) so that i can move the comp camera around the pieces.
    Thanks for your help
    Juan O
    Benjamin Tubb replied 20 years, 4 months ago 2 Members · 1 Reply
  • Benjamin Tubb
    April 26, 2006 at 10:52 pm
    Would it work if you precomped the shatter, then collapsed transformations/continually rasterized, then just stopped the layer using time remap?
    I’m not sure… It’s a bit confusing to me when there’s a 3d effect on a 2d layer, using the comp camera, and it’s precomped.
    Ben Tubb
    “Of course, I could be wrong. In fact, I’m probably wrong.”
