Activity Forums Adobe After Effects Help with Screen Text Plugin
  • Help with Screen Text Plugin
    Posted by Snowcarver on October 10, 2006 at 5:36 am
    I am trying to make a digital bathroom scale appear to change weights. I am trying to use Digital Anarchy’s Screen text plug in. I have a text document with random weights. The problem is I don’t want to have the text scroll up I just want it to flash of and the new one come on. When I put the Scroll speed to zero the numbers move to fast to see. Can anyone help or give other ideas.
    Thanks in advance.
    Cory
    Snowcarver replied 19 years, 11 months ago 2 Members · 2 Replies
  • Jim Tierney
    October 10, 2006 at 10:55 pm
    Set the Display Speed to 1.0
    Set Frequency of Overwrite to 15.0
    Display speed will cause one character to be drawn on the screen every frame. You could also set it to say, 7 characters and have entire words or numbers appear instead of individual characters.
    Frequency of Overwrite tells Screen Text how often you want to overwrite the current line. If there’s no scroll speed, this will give you the effect you want. If you set it to 15, then every 15 frames it will read a new line from your text file. If you want lines replaced faster, set it to a lower number.
    Hope that helps,
    Jim
    Jim Tierney
    Digital Anarchy
    http://www.digitalanarchy.com
    415-586-8434
  • Snowcarver
    October 11, 2006 at 3:42 am
    Thanks it worked.
    Cory
