Activity › Forums › VEGAS Pro › help with rendering.. please look
  • John Rofrano
    May 31, 2013 at 11:41 pm
    I see that it’s a bit jumpy. What frame rate did you capture at? (i.e., the frame rate of the source video?) What frame rate did you render to? Maybe post a screen shot of your project properties and render properties.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Neal Wight
    June 1, 2013 at 7:58 am
    template hdv 720-30p (1280×720, 29, 970fps)
    Field order none…. pixel ratio 1.0000 (square)
    Frame rate 29,970(ntsc)
    Pixel format 32 bit floating point
    Full res best
    Motion blur gaussian..
    Hd pvr records at 1920x1080x128, 29.871p to mp4 file.
    Hope u understand this
  • John Rofrano
    June 1, 2013 at 10:34 am
    Why is your pixel format 32-bit? You’re not using 10-bit source video and have no need for this. Change it back to 8-bit and see if this makes a difference.
    I assume those were your project properties. How about your render template?
    A screen shot would be a whole lot easier to understand.
    ~jr
  • Neal Wight
    June 1, 2013 at 11:41 am
    excuse the reflection lol, these settings are what has been recommended to me and a bit of trial and error..
  • John Rofrano
    June 1, 2013 at 1:56 pm
    [neal wight] “excuse the reflection lol,”
    Do realize that your computer has a Print Screen key that will capture the screen instead of using a camera?
    I’m not sure why your project settings are 29.871 fps but I’m guessing that is your problem. The HD PVR should be capturing at 29.97 and your project should be at 29.97.
    Alternately, Disable Resample for every single event on your timeline but it’s a lot easier to set your frame rate correctly from the start.
    ~jr
  • Neal Wight
    June 1, 2013 at 2:03 pm
    Im a total noob and trying to learn fast…
    How do I set frame rate to match etc??
    I was using the arcsoft software but its so buggy I changed to vp.
    In arcsoft it was uploading in 1080 with perfect render but since I changed im really struggling to get it too look gd..
    Thanks for your help
