Activity Forums Adobe Premiere Pro Help with premiere pro project settings
  • Help with premiere pro project settings
    Posted by Don Chard on December 19, 2009 at 7:49 pm
    Hey guys,
    For the past 3 weeks I’ve been editing a video based on still images captured using Snagit from Powerpoint, and their size is: 697 x 511
    When I created the project, I went with the default settings of
    DV/NTSC
    720 x 480 ( 4:3 )
    29.97 FPS
    Within this video I’ve also imported a 13 minute video tutorial from Camtasia, which is recorded at 800 x 600.
    The whole video is now 32 minutes long since I’m narrating throughout all images, and I’ve also added several music clips in the background, and have matched the voice with the images, and music, and added a lot of transitions for each image throughout the video.
    For the past 3 days I’ve been trying to export this to a watchable format for the web, and nothing I try seems to work.
    I’ve tried exporting an AVI raw file, and ended up with a 53 GB file.
    Then I started testing exporting small clips, and exporting at
    H.264 High Quality
    720 x 480
    These settings seem to give me some good files, but when it comes to exporting the camtasia tutorial I get horrible output.
    I would like for this video to be watchable on the web, and preferably export to a nice .avi back into camtasia studio in order to get an MP4 file or flash file with the HTML embedded.
    I’ve tried creating another sequence with 800 x 600 ratio, and tried copying my entire timeline, but that doesn’t work.
    This is only the 2nd video I’ve ever edited, and clearly I’m using the wrong settings, and not sure what to do anymore. 🙁
    I must’ve tried like 50 different times, and sometimes I think I’m making progress, but then the camtasia tutorial just doesn’t budge.
    Please help I know I have the WRONG project, import, or export settings, and I just dont’ know what to do anymore.
    I didn’t take any video editing courses, I just watched a Lynda.com tutorial and learned Premiere on my own. The video editing part was fun, but exporting the video….. that’s another story. 🙁
    Don Chard replied 16 years, 9 months ago 4 Members · 12 Replies
  • 12 Replies
  • Vince Becquiot
    December 19, 2009 at 9:43 pm
    Where are you posting the videos? AVIs / WMV won’t play back on Macs, and not everyone on the PC side has Quicktime, which leaves you with Flash/H.264.
    But that needs to be embedded somehow. If you are going to YouTube, H.264 is also a good choice.
    As far as settings go, start with 512×288 square pixels at 900 Kb/s (for Flash flv), or 512×288 square pixels H.264 at 3Mb/s for YouTube.
    You would also have to crop 8 pixels left and right in the export panel to lose the black bars.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Don Chard
    December 19, 2009 at 9:50 pm
    Thanks Vince
    I guess the real issue I’m having is that my sequence is 720 x 480 ( 0.9 ) and all my assets are ( 1.0 )
    Everytime I’ve exported something, only a couple times have I gotten a nice workable video, but the Camtasia video is always blurry and not clear.
    I will be hosting the video on my server, and I would like to export either an .avi or .mov file, so that I can import back into Camtasia to create the flash file for the web.
    Thanks for the input, I’ve tried MANY export settings, and I can’t get anything to work
  • Malcolm Neakl
    December 19, 2009 at 10:55 pm
    great quality for me is JPEG 2000 and Animation, but size wise, dont bother. H264 and MPEG4 are good compressors, the best of all pro has to offer if youre uploading to youtube, or flash but I’m not an expert with flash settings.
    You should find a way to interpret your assets to be the same size and aspect ratio before exporting.
    otherwise it will be good for one set, but display others all weird.
    Remember your project settings are only for editing and what you see in pro. They don’t effect the original files, or the quality of your exported files. Only your export settings do.
    I made that mistake. Editing in AVI animation, or uncompressed. Took a year to render.
    in my exp. all the AVI compressors are half as good as thier Quicktime counterparts.
    To test this, go to new item, bring up colour bars. make it ten seconds, and half way through make it rotate 360o. that will give you a good view of how each compressor handles colour and pixels.
    sto pro veritate
  • Don Chard
    December 19, 2009 at 11:33 pm
    ” You should find a way to interpret your assets to be the same size and aspect ratio before exporting.
    otherwise it will be good for one set, but display others all weird. ”
    Do you mean within the timeline?
    Does the fact that my sequence settings are 720 x 480 ( .919 ) and all my assets are ( 1.0 ) affect the output?
    I believe this is where I’ve gone wrong.
    I’ve tried creating a new sequence at 800 x 600 ( 1.0 ) and copying and pasting my timeline items to get a fresh start, and when it gets rendered it gets cropped and stretched all weird.
    I’m really running out of ideas as to what to do, and I need to get this video done yesterday. 🙁
  • Malcolm Neakl
    December 20, 2009 at 12:11 am
    changing the settings of your sequence will only alter the way pro lets you see the project. This is for editing purposes. It doesnt effect the files you use or export. So if you have photo that is 1024×576 and your time line/project settings are for 800×600, it doesnt alter the photo, it just means the view window wont show the sides, and you’ll see black bars at the top. but, if you export it as 1024×576, it will be just like your photo. not like you see it in premier pro.
    you can see in your project window that one piece of footage is 1024×576 1.422par and 720 x 480 .919 par. so no matter how much in the timeline project it looks right, until you make the original file the same PAR as the other files, the exported videos aspect ratio will adversely effect one or the other respectively.
    right click one piece of footage in your project window and interpret the footage to a PAR of the others then just resize it to make it look normal.
    remember project settings is just for the premiere pro sequence viewer. Interpreting your footage in the project assets window will equalise everything.
    sto pro veritate
  • Malcolm Neakl
    December 20, 2009 at 12:36 am
    in regards to editing in a 1.0 PAR? lol, this is a pain. because the DV1 NTSC (pal for me), uses a really fast codec. Which is why its in there. What you’ll have to do to make the viewer see what you actually have is get the project settings to 1.0 PAR. you cant do that with the dv ntsc. so on a new project, choose custom settings. general> editing mode – video for windows (or mac alternative if youre on mac)
    That all of a sudden allows you full control of the project PAR and frame size.
    so 1.0
    and whatever window size you like.
    you can go to town coz it wont effect your quality, only the quality of how you see it in the editing suite.
    so the lower the better. As I recall the Codecs are all slow as hell thats
    Video Rendering>File format then compressor. I cant remember which ones are fastest. But speed is the key not quality, since as I said, its just for while you edit. Just while you can interpret all the footage to 1.0 PAR in the project assets window when you import all your work to this new project and then resize them so they dont look squashed after you have harmonised the PAR.
    Im no expert, but ive had similar issues, and hopefully this is enough know how to help.
    remember, even if your project settings are using a black and white only codec (cinepak radius codec black and white setting) and all your footage is looking black and white, thats only the viewer, your project will export in colour regardless as per your export settings.
    sto pro veritate
  • Don Chard
    December 20, 2009 at 12:52 am
    Thanks for the feedback, at least it gives me hope that it’s not the sequence settings that are the problem.
    The video fits perfectly into Premiere’s preview monitor, it’s only when exporting that it comes out all blurry.
    I think I understand what you’re saying now….
    Because my video is 800 x 600 and my images are 697 x 511, they are conflicting with each other and therefore not exporting properly.
    So I guess, what I need to do is capture a new set of images at 800 x 600?
    And then just replace 697 x 511 images with 800 x 600 images, right?
    I just don’t want to do the whole sequence over again, but I could easily replace the images, and add the transition effects right away, without having to mess with the audio.
    Here are my images & video settings
    Sequence: 720 x 480 ( .9 )
    Type: JPEG
    File Size: 87 KB
    Image Size: 697 x 511
    Pixel Depth: 32
    Pixel Aspect Ratio: 1.0
    Type: QuickTime Movie
    File Size: 24.4 MB
    Image Size: 800 x 600
    Pixel Depth: 24
    Frame Rate: 30.00
    Source Audio Format: 44100 Hz – 16 bit – Mono
    Project Audio Format: 44100 Hz – 32 bit floating point – Mono
    Total Duration: 00;04;53;05
    Average Data Rate: 85 KB / second
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).
    Video:
    There are 8796 frames with a duration of 1/30th.
    Video track 1:
    Duration is 0;04;53;14
    Average frame rate is 30.00 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 800 x 600
    Compressor = H.264
    Quality = High (4.00)
    Temporal = High (4.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 16 bit – Mono
    Rate = 44100.0000 Hz
    Compressor = MPEG-4 Audio
  • Don Chard
    December 20, 2009 at 1:12 am
    So basically, what I’m going to do is re-create all images at an 800 x 600 resolution, and then replace them right into my timeline.
    Therefore, the images and video will be the EXACT SAME dimensions, so hopefully now I will get the desired output needed. 🙂
    I’m already testing a resized image now, with the video to see how it turns out.
    Will keep you posted, thanks for the feedback!
  • Malcolm Neakl
    December 20, 2009 at 3:18 pm
    Since both your assets have the same pixel aspect ratio basically your video should look normal since your export settings are exactly the same as your video. Your pictures should be non pixelated, and just have black edges due to them not filling out the space correctly. try viewing the video on quicktime player.
    Since I just tried a similar conundrum as your project and windows media player would not show the visuals, but quicktime played it as I expected.
    if it is your original video asset footage that is the problem, perhaps you have funny video data. Like my XL2, which records with 960 pixels, squeezes that image signal to 720 pixels, then to view it correctly you have to make the width 1024! at 1.0 PAR, despite it being recognised as 1.422 PAR original asset footage.
    with my xl2, if i export at the pixel aspect ratio of my original dv tape signal (1.422), which is the standard thing to do, I get a squashed image.
    ive yet to learn why Canon gave it 960×576 instead of 1024×576.
    sto pro veritate
  • Don Chard
    December 20, 2009 at 4:13 pm
    Thanks for the info.
    I kept digging around last night, and finally ran into this info:
    https://forums.adobe.com/message/2063028
    In a separate article it also suggested that I needed to upgrade to Premiere Pro 4.1 since it had an improved rendering engine.
    So, that’s why no matter what export settings I attempted, the camtasia footage never exported correctly, and was always blurry and unclear.
    Now to try the advice given in the article above. 🙂
    Thanks very much for the clarifications, and information given here, it is much appreciated!
