Activity Forums Adobe Photoshop Help with photoshop CS3
  • Help with photoshop CS3
    Posted by None None on July 21, 2008 at 7:15 pm
    I can’t figure out how to make a grid pattern in Photoshop CS3 extended. I’m using a tutorial and it says to ‘Create a white 50×50 pixels large-celled grid under the layer containing the cars, with the help of Pencil Tool, 1px in diameter.’ I looked for about a half hour and I can’t find any grid option, any help is appreciated, thanks 🙂
    The tutorial I am using is here:
    https://colorifer.com/photoshop_tutorial_collage_creating.html
    None None replied 18 years, 1 month ago 2 Members · 2 Replies
  • Tom Hepburn
    July 22, 2008 at 9:53 pm
    Start an empty layer
    Under the filter drop down, in the top portion there is something called “vanishing point.” draw a grid with the tools there, and there is a little arrow at the top where you would tell it to “render grids to Photoshop.” That is what this person it talking about.
    There are many ways to create a grid, but I have rarely used this one. That’s not to say this isn’t a good way.
    Good luck.
    T
  • None None
    July 23, 2008 at 11:49 am
    Thank you so much! It worked.
