Activity Forums Adobe After Effects Help With Paths And Layers
  • Help With Paths And Layers
    Posted by Kaptivate_ag on October 18, 2006 at 7:03 am
    I have a composition here where the light follows the path ect ect. Everyone has seen it before but after adapting a sample file for this I am confused as to what is wrong.
    Basically, the path for the light to travel was re-designed and the flare flows along it perfectly but the light trail does not. It appears offset.
    My comp size is different to the lighttrail comp size, but in theory it shouldnt matter as their both running along on their own.
    For your convenience, I have posted the zip file up so you can look and hopefully, someone can tell me how to correct it so that the light trail layer flows along the path the same as the flare layer.
    Thanks! Hope you can help!
    https://www.kaptivate.com.au/street_up_comp.zip – It should become obvious what the problem is once you look at it with the track layer selected.
    Ignore all movement on the other layer as there is no point adding the same sudo camera moves to the light layer if its not working yet.
    Kaptivate_ag replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
